> For the complete documentation index, see [llms.txt](https://guides.noloco.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://guides.noloco.io/settings/mcp-integration/mcp-faq.md). Agents can also search and read this documentation through its [MCP server](https://guides.noloco.io/~gitbook/mcp).
# MCP FAQ
Common questions about the Noloco MCP server.
**What's the difference between the builder MCP and the app MCP?**\
The [builder MCP](https://guides.noloco.io/settings/mcp-integration.md#builder-mcp) is for builders. One connection covers every app where you're a data admin, sees all data, and can build apps you have builder access to. The [app MCP](https://guides.noloco.io/settings/mcp-integration.md#app-mcp) is a separate server for each app, for that app's users. It acts within the user's role, works with records only, and can't delete them.
**Can I connect multiple AI clients with the same Noloco account?**\
Yes. Each client (Claude Desktop, Claude Code, ChatGPT, Gemini, GitHub Copilot, Cursor, Windsurf, etc.) runs its own OAuth sign-in and gets its own token. They can all be connected at once, and each can have a different scope or set of approved apps.
**Does using the MCP server count against my API rate limits?**\
The data tools do. They read and write records through the same Noloco data API as Zapier, Make, and direct REST calls, so they are subject to the same rate limits as your plan.
The build tools change how your app is set up rather than its records, so they don't go through the data API. Three of them (`sections`, `manage_canvas`, and `edit_workflow`) run Noloco's AI and are limited by your [AI credits](https://guides.noloco.io/nola/credits-and-usage.md) instead. Only one of those runs at a time on an app from the same connection, and your plan caps how many AI runs your team can have going at once.
**Can the AI see data from all my Noloco apps?**\
Only the ones you approve. During sign-in you pick which apps the client can access; by default it's every app where you're a data admin. You can re-run the consent flow at any time to add or remove apps.
**Can app users who aren't data admins connect their own AI?**\
Yes, if their role has [Agent access](https://guides.noloco.io/users-and-permissions/user-roles-and-permissions.md#agent-access). They connect to the app's own [app MCP](https://guides.noloco.io/settings/mcp-integration.md#app-mcp) server, which works within their permissions.
**What happens if the AI tries to do something it shouldn't?**\
The MCP server enforces the same data validation as the rest of the Noloco API. Required fields, field type constraints, and relationship rules all apply. Every tool call is also checked against your live data admin role on the target app, and build tools check your builder access too. Losing either takes effect immediately.
Nothing on the Noloco side asks you to approve a change. The server tells the assistant to check with you before it deletes something or publishes, and most clients also let you approve each tool call yourself.
**Does the MCP server give the AI access to my app's pages and UI?**\
Yes, on apps you can build. If you have builder access and approved read + write, the assistant can read and change your pages, views, forms, buttons, workflows, roles, permissions, and settings, and publish them. On other apps it only sees tables, fields, and records. See [Who can build with the MCP](https://guides.noloco.io/settings/mcp-integration.md#who-can-build-with-the-mcp).
**Will my users see the assistant's changes right away?**\
Not for most changes to the app itself. Pages and everything on them, workflow actions, and most app settings wait as drafts until the assistant publishes, just like edits you make in the builder. Records, tables, fields, roles, and permissions change at once. See [Drafts and publishing](https://guides.noloco.io/settings/mcp-integration.md#drafts-and-publishing).
**Is there an extra cost for using the MCP server?**\
Not for the MCP itself. MCP access is included in all Noloco plans that have API access. Check your [plan limits](https://guides.noloco.io/settings/plan-limits-and-usage.md) if you are unsure whether your plan includes API access.
The three build tools that run Noloco's AI (`sections`, `manage_canvas`, and `edit_workflow`) use your team's [AI credits](https://guides.noloco.io/nola/credits-and-usage.md), the same as asking [Nola](https://guides.noloco.io/nola.md).
GET https://guides.noloco.io/settings/mcp-integration/mcp-faq.md?ask=<question>&goal=<user_goal>
