> For the complete documentation index, see [llms.txt](https://guides.noloco.io/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://guides.noloco.io/settings/general-settings/live-mode.md).
# Live Mode
Turn on live-mode to allow your users to log in
When you've finished designing, building & testing your App - you're ready to turn on Live Mode 🎉
It is only at this point that all non-builder Users you have added to your app will be able to login. You can toggle this on using this link: <https://portals.noloco.io/~/_/settings/project>
<figure><img src="https://319575345-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MifpIQWu0HCVYAt51oT%2Fuploads%2Fgit-blob-c1194f32b71d73412927a505ba3aafc949399cf4%2FScreenshot%202022-10-13%20at%2013.43.38.png?alt=media" alt=""><figcaption></figcaption></figure>
GET https://guides.noloco.io/settings/general-settings/live-mode.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `build a script that syncs our docs to a CMS` lets GitBook tailor the answer to that use case.
